Configures the PS/2 keyboard data and clock pins.
CONFIG ATEMU = int , DATA = data, CLOCK=clock [,INIT=VALUE]
Int |
The interrupt used such as INT0 or INT1. |
DATA |
The pin that is connected to the DATA line. This must be the same pin as the used interrupt. |
CLOCK |
The pin that is connected to the CLOCK line. |
INIT |
An optional value that will identify the keyboard. By default or when omitted this is &HAB83. The code that identifies a keyboard. Some mother boards/BIOS seems to require the reverse &H83AB. By making it an option you can pass any possible value. The MSB is passed first, the LSB last. |
Male
(Plug) |
Female
(Socket) |
5-pin DIN (AT/XT):
1 - Clock 2 - Data 3 - Not Implemented 4 - Ground 5 - +5v |
Male
(Plug) |
Female
(Socket) |
6-pin Mini-DIN (PS/2):
1 - Data 2 - Not Implemented 3 - Ground 4 - +5v 5 - Clock 6 - Not Implemented |
Old PC’s are equipped with a 5-pin DIN female connector. Newer PC’s have a 6-pin mini DIN female connector.
The male sockets must be used for the connection with the micro.
Besides the DATA and CLOCK you need to connect from the PC to the micro, you need to connect ground. You can use the +5V from the PC to power your microprocessor.
The config statement will setup an ISR that is triggered when the INT pin goes low. This routine you can find in the library.
The ISR will retrieve a byte from the PC and will send the proper commands back to the PC.
The SENDSCANKBD statement allows you to send keyboard commands.
Note that unlike the mouse emulator, the keyboard emulator is also recognized after your PC has booted.
The PS2 Keyboard and mouse emulator needs an additional commercial addon library.
'name : ps2_kbdemul.bas
'purpose : PS2 AT Keyboard emulator
'micro : 90S2313
'suited for demo : no, ADD ONE NEEDED
'commercial addon needed : yes
$lib "mcsbyteint.lbx" ' use optional lib since we use only bytes
'configure PS2 AT pins
Enable Interrupts ' you need to turn on interrupts yourself since an INT is used
Config Atemu = Int1 , Data = Pind.3 , Clock = Pinb.0
' ^------------------------ used interrupt
' ^----------- pin connected to DATA
' ^-- pin connected to clock
'Note that the DATA must be connected to the used interrupt pin
Waitms 500 ' optional delay
'rcall _AT_KBD_INIT
Print "Press t for test, and set focus to the editor window"
Dim Key2 As Byte , Key As Byte
Key2 = Waitkey() ' get key from terminal
Select Case Key2
Case "t" :
Waitms 1500
Sendscankbd Mark ' send a scan code
Case Else
End Select
Print Hex(key)
Mark: ' send mark
Data 12 , &H3A , &HF0 , &H3A , &H1C , &HF0 , &H1C , &H2D , &HF0 , &H2D , &H42 , &HF0 , &H42
' ^ send 12 bytes
' m a r k
