Key |
Action |
LEFT ARROW |
One character to the left |
RIGHT ARROW |
One character to the right |
UP ARROW |
One line up |
DOWN ARROW |
One line down |
HOME |
To the beginning of a line |
END |
To the end of a line |
PAGE UP |
Up one window |
PAGE DOWN |
Down one window |
CTRL+LEFT |
One word to the left |
CTRL+RIGHT |
One word to the right |
CTRL+HOME |
To the start of the text |
CTRL+END |
To the end of the text |
CTRL+ Y |
Delete current line |
INS |
Toggles insert/over strike mode |
F1 |
Help (context sensitive) |
F2 |
Run simulator |
F3 |
Find next text |
F4 |
Send to chip (run flash programmer) |
F5 |
Run |
F7 |
Compile File |
F8 |
Step |
F9 |
Set breakpoint |
F10 |
Run to |
CTRL+F7 |
Syntax Check |
CTRL+F |
Find text |
CTRL+G |
Go to line |
CTRL+K+x |
Toggle bookmark. X can be 1-8 |
CTRL+L |
LCD Designer |
CTRL+M |
File Simulation |
CTRL+N |
New File |
CTRL+O |
Load File |
CTRL+P |
Print File |
CTRL+Q+x |
Go to Bookmark. X can be 1-8 |
CTRL+R |
Replace text |
CTRL+S |
Save File |
CTRL+T |
Terminal emulator |
CTRL+P |
Compiler Options |
CTRL+W |
Show result of compilation |
CTRL+X |
Cut selected text to clipboard |
CTRL+Z |
Undo last modification |
SHIFT+CTRL+Z |
Redo last undo |
CTRL+INS |
Copy selected text to clipboard |
SHIFT+INS |
Copy text from clipboard to editor |
CTRL+SHIFT+J |
Indent Block |
CTRL+SHIFT+U |
Unindent Block |
Select text |
Hold the SHIFT key down and use the cursor keys to select text. or keep the left mouse key pressed and drag the cursor over the text to select. |
