#AUTOCODE
#IF ELSE ENDIF
$AESKEY
$ASM
$BAUD
$BAUD1
$BGF
$BIGSTRINGS
$BOOT
$CRYPT
$CRYSTAL
$DATA
$DBG
$DEFAULT
$EEPLEAVE
$EEPROM
$EEPROMHEX
$EEPROMSIZE
$END ASM
$EXTERNAL
$FILE
$FRAMECHECK
$FRAMESIZE
$HWCHECK
$HWSTACK
$INC
$INCLUDE
$INITMICRO
$LCD
$LCDPUTCTRL
$LCDPUTDATA
$LCDRS
$LCDVFO
$LIB
$LOADER
$LOADERSIZE
$MAP
$NOCOMPILE
$NOINIT
$NORAMCLEAR
$NORAMPZ
$NOTRANSFORM
$PROG
$PROGRAMMER
$PROJECTTIME
$REGFILE
$RESOURCE
$ROMSTART
$SERIALINPUT
$SERIALINPUT1
$SERIALINPUT2LCD
$SERIALOUTPUT
$SERIALOUTPUT1
$SIM
$SOFTCHECK
$SWSTACK
$TIMEOUT
$TINY
$VERSION
$WAITSTATE
$XA
$XRAMSIZE
$XRAMSTART
- 1 -
1WIRECOUNT
1WIRESEARCHNEXT
1WREAD
1WRESET
1WSEARCHFIRST
1WVERIFY
1WWRITE
- A -
ABS
ACOS
Adding XRAM
Additional Hardware
ADR
ADR2
AESDECRYPT
AESENCRYPT
ALIAS
ARDUINO
ARRAY
ASC
ASCII chart
ASIN
Assembler mnemonics
AT_EMULATOR
AT86RF401
AT90CAN128
AT90PWM216
AT90PWM2-3
AT90S1200
AT90S2313
AT90S2323
AT90S2333
AT90S2343
AT90S4414
AT90S4433
AT90S4434
AT90S8515
AT90S8535
AT90USB162
ATMEGA103
ATMEGA128
ATMEGA1284P
ATMEGA16
ATMEGA161
ATMEGA162
ATMEGA163
ATMEGA164P
ATMEGA165
ATMEGA168
ATMEGA168P
ATMEGA169
ATMEGA16M1
ATMEGA16U2
ATMEGA16U4
ATMEGA2560
ATMEGA2561
ATMEGA32
ATMEGA323
ATMEGA324P
ATMEGA325
ATMEGA3250P
ATMEGA328
ATMEGA328P
ATMEGA329
ATMEGA32M1
ATMEGA32U
ATMEGA32U2
ATMEGA406
ATMEGA48
ATMEGA48P
ATMEGA603
ATMEGA64
ATMEGA640
ATMEGA644P
ATMEGA645
ATMEGA649
ATMEGA64M1
ATMEGA8
ATMEGA8515
ATMEGA8535
ATMEGA88
ATMEGA88P
ATMEGA8A
ATMEGA8U2
ATN
ATN2
Attaching an LCD Display
ATtiny12
ATtiny13
ATtiny15
ATTINY167
ATTINY20
ATtiny22
ATtiny2313
ATtiny24
ATtiny25
ATtiny26
ATtiny261
ATtiny4313
ATtiny44
ATtiny45
ATtiny461
ATtiny48
ATtiny84
ATtiny85
ATtiny861
ATtiny88
ATXMEGA
ATXMEGA128A1
ATXMEGA128A3
ATXMEGA128D3
ATXMEGA128D4
ATXMEGA16A4
ATXMEGA16D4
ATXMEGA192A3
ATXMEGA192D3
ATXMEGA256A3
ATXMEGA256A3B
ATXMEGA256D3
ATXMEGA32A4
ATXMEGA32D4
ATXMEGA64A1
ATXMEGA64A3
ATXMEGA64D3
ATXMEGA64D4
AVR Internal Hardware
AVR Internal Hardware Port B
AVR Internal Hardware Port D
AVR Internal Hardware Watchdog timer
AVR Internal Registers
AVR ISP Programmer
AVR-DOS File System
- B -
BASCOM Editor Keys
BASE64DEC
BASE64ENC
BAUD
BAUD1
BCCALL
BCCARD
BCD
BCDEF
BCINIT
BCRESET
BIN
BIN2GRAY
BINVAL
BIT
BITS
BITWAIT
BLOAD
BOX
BOXFILL
BSAVE
BUFSPACE
BYTE
BYVAL
- C -
CALL
CALL
CONFIG SUBMODE
CASE
Changes compared to BASCOM-8051
CHARPOS
CHECKFLOAT
CHECKSUM
CHECKSUMXOR
CHR
CIRCLE
CLEAR
CLOCKDIVISION
CLOSE
CLOSESOCKET
CLS
Compact FlashCard Driver
CONFIG
CONFIG 1WIRE
CONFIG ACI
CONFIG ADC
CONFIG ADCx
CONFIG ATEMU
CONFIG BASE
CONFIG CLOCK
CONFIG CLOCKDIV
CONFIG COM1
CONFIG COM2
CONFIG COMx
CONFIG DAC
CONFIG DACA
CONFIG DACB
CONFIG DATE
CONFIG DCF77
CONFIG DEBOUNCE
CONFIG DMA
CONFIG DMA
CONFIG DMACHx
CONFIG DMACHx
CONFIG DMXSLAVE
CONFIG DP
CONFIG EEPROM
CONFIG EVENT_SYSTEM
CONFIG EXTENDED_PORT
CONFIG GRAPHLCD
CONFIG HITAG
CONFIG I2CDELAY
CONFIG I2CSLAVE
CONFIG INPUT
CONFIG INTx
CONFIG KBD
CONFIG KEYBOARD
CONFIG LCD
CONFIG LCDBUS
CONFIG LCDMODE
CONFIG LCDPIN
CONFIG OSC
CONFIG PORT
CONFIG POWER_REDUCTION
CONFIG POWERMODE
CONFIG PRINT
CONFIG PRINT0
CONFIG PRINT1
CONFIG PRINT2
CONFIG PRINT3
CONFIG PRINTBIN
CONFIG PRIORITY
CONFIG PS2EMU
CONFIG RC5
CONFIG SCL
CONFIG SDA
CONFIG SERIALIN
CONFIG SERIALOUT
CONFIG SERVOS
CONFIG SHIFTIN
CONFIG SINGLE
CONFIG SPI
CONFIG SPIC, SPID, SPIE, SPIF
CONFIG SUBMODE
CONFIG SYSCLOCK
CONFIG TC
CONFIG TCPIP
CONFIG TIMER0
CONFIG TIMER1
CONFIG TIMER2
CONFIG TWI
CONFIG TWISLAVE
CONFIG USB
CONFIG VPORT
CONFIG WAITSUART
CONFIG WATCHDOG
CONFIG X10
CONFIG XRAM
CONST
Constants
COS
COSH
COUNTER0 and COUNTER1
CPEEK
CPEEKH
CRC16
CRC16UNI
CRC32
CRC8
CRYSTAL
CURSOR
custom design
- D -
DATA
DATE
DATE$
DATETIME
DAYOFWEEK
DAYOFYEAR
DBG
DCF77TIMEZONE
DEBOUNCE
DEBUG
DECLARE
DECLARE FUNCTION
DECLARE SUB
DECR
DEFBIT
DEFINT
DEFLCDCHAR
DEFLNG
DEFSNG
DEFWORD
DEFxxx
DEG2RAD
DELAY
DELCHAR
DELCHARS
DIM
DIR
DISABLE
DISKFREE
DISKSIZE
DISPLAY
DMACH0
DMACH1
DMACH2
DMACH3
DO
DOUBLE
DOWNTO
DriveCheck
DriveGetIdentity
DriveInit
DriveReadSector
DriveReset
DriveWriteSector
DTMFOUT
- E -
ECHO
Edit Copy
Edit Cut
Edit Find
Edit Find Next
Edit Goto
Edit Goto Bookmark
Edit Indent Block
Edit Paste
Edit Redo
Edit Remark Block
Edit Replace
Edit Toggle Bookmark
Edit Undo
Edit Unindent Block
Elektor CF-Interface
ELSE
ELSE
IF-THEN-ELSE-END IF
ENABLE
ENCODER
ENCRYPT
END
END IF
END SELECT
EOF
ERAM
Error Codes
EUROTIMEDATE
EXIT
EXP
EXTENDED I2C
- F -
File Close
File Exit
File New
File Open
File Print
File Print Preview
File Save
File Save As
FILEATTR
FILEDATE
FILEDATETIME
FILELEN
FILETIME
FIX
FLIP
FLUSH
FM24C16
FM24C256
FM24C64
FM25C256
Font Editor
FOR
FORMAT
FOR-NEXT
FOURTHLINE
FP_TRIG
FRAC
FREEFILE
FUNCTION
FUSING
- G -
GET
GETADC
GETATKBD
GETATKBDRAW
GETDSTIP
GETDSTPORT
GETKBD
GETRC
GETRC5
GETREG
GETSOCKET
GETTCPREGS
GLCD
GLCDCMD
GLCDDATA
glcdR7565R
GLCDSED
GlcdSSD1325_96x64
GOSUB
GOTO
GRAY2BIN
- H -
Help About
Help Credits
Help Index
Help Knowledge Base
Help MCS Forum
Help MCS Shop
Help Support
HEX
HEXVAL
HEXVAL
HEXVAL
HIGH
HIGHW
HOME
- I -
I2C TWI Slave
I2C_TWI
I2CINIT
I2CRBYTE
I2CRECEIVE
I2CREPSTART
I2CSEND
I2CSLAVE
I2CSTART
I2CSTOP
I2CSTOP: I2CRBYTE: I2CWBYTE
I2CWBYTE
I2START
IDLE
CONFIG POWERMODE
IDLE
IF
IF-THEN-ELSE-END IF
INCR
Index
INITFILESYSTEM
INITLCD
INKEY
INP
INPUT
INPUTBIN
INPUTHEX
INSERTCHAR
Install on multiple computers
Installation of BASCOM
INSTR
INT
INTEGER
IP2STR
ISCHARWAITING
ISP programmer
- K -
Keyword Reference
KILL
KITSRUS Programmer
- L -
Language Fundamentals
Lawicel BootLoader
LCASE
LCD
LCD RGB-8 Converter
LCD4.LIB
LCD4BUSY
LCD4E2
LCDAT
LCDAUTODIM
LCDCONTRAST
LCD-EPSON
LEFT
LEN
LIBUSB
LINE
LINE INPUT
LINEINPUT
LOAD
LOADADR
LOADLABEL
LOADWORDADR
LOC
LOCAL
LOCATE
LOF
LOG
LOG10
LONG
LOOKDOWN
LOOKUP
LOOKUPSTR
LOOP
LOW
LOWERLINE
LTRIM
- M -
MACRO
MAKEBCD
MAKEDEC
MAKEINT
MAKEMODBUS
MAKETCP
MAX
MCS Bootloader
MCS Universal Interface Programmer
MCSBYTE
MCSBYTEINT
MEMCOPY
Memory usage
MID
MIN
Mixing ASM and BASIC
MOD
MODBUS Slave Server
- N -
NBITS
New CF-Card Drivers
Newbie problems
NEXT
- O -
ON INTERRUPT
ON VALUE
OPEN
Options Communication
Options Compiler
Options Compiler 1WIRE
Options Compiler Chip
Options Compiler Communication
Options Compiler I2C
Options Compiler LCD
Options Compiler Output
Options Compiler SPI
Options Environment
Options Monitor
Options Printer
Options Programmer
Options Simulator
OUT
- P -
PCF8533
PEEK
PG302 programmer
POKE
POPALL
POWER
CONFIG POWERMODE
POWER
POWER MODE
Power Up
POWERDOWN
POWERSAVE
PRINT
PRINTBIN
PROGGY
Program Compile
Program Development Order
Program Send to Chip
Program Show Result
Program Simulate
Program Syntax Check
PS2MOUSE_EMULATOR
PS2MOUSEXY
PSET
PULSEIN
PULSEOUT
PUSHALL
PUT
- Q -
QUOTE
- R -
RAD2DEG
RC5SEND
RC5SENDEXT
RC6SEND
READ
READEEPROM
READHITAG
READMAGCARD
READSIG
READSIGNATURE
REM
REPLACECHARS
Resellers
Reserved Words
RESET
RESTORE
RETURN
RIGHT
RND
ROTATE
ROUND
RTRIM
Running BASCOM-AVR
- S -
Sample Electronics cable programmer
SECELAPSED
SECOFDAY
SEEK
SELECT
SELECT-CASE-END SELECT
SENDSCAN
SENDSCANKBD
SERIN
SEROUT
SET
SETFONT
SETIPPROTOCOL
SETREG
SETTCP
SETTCPREGS
SGN
SHIFT
SHIFTCURSOR
SHIFTIN
SHIFTLCD
SHIFTOUT
SHOWPIC
SHOWPICE
SIGNATURE
SIN
SINGLE
SINH
SOCKETCONNECT
SOCKETLISTEN
SOCKETSTAT
SONYSEND
SORT
SOUND
SPACE
SPC
SPIIN
SPIINIT
SPIMOVE
SPIOUT
SPISLAVE
SPLIT
SQR
START
STCHECK
STEP
STK500 Programmer
STK600
STOP
STR
STR2DIGITS
STRING
SUB
CONFIG SUBMODE
SUB
Supported Programmers
SWAP
SYSDAY
SYSSEC
SYSSECELAPSED
- T -
TAN
TANH
TCC0
TCC1
TCD0
TCD1
TCPCHECKSUM
TCPIP
TCPREAD
TCPWRITE
TCPWRITESTR
THEN
THIRDLINE
TIME
TIME$
TIMER
TIMER0
TIMER1
Tips and tricks
TOGGLE
Tools Batch Compile
Tools Graphic Converter
Tools LCD Designer
Tools LIB Manager
Tools PDF Update
Tools Plugin Manager
Tools Resource Editor
Tools Stack Analyzer
Tools Terminal Emulator
TRIM
TWI_START
- U -
UCASE
UDPREAD
UDPWRITE
UDPWRITESTR
UPPERLINE
USB Addon
USB-ISP Programmer
Using RS485
Using the 1 WIRE protocol
Using the I2C protocol
Using the SPI protocol
USING the UART
- V -
VAL
VARPTR
VER
VERSION
View Error Panel
View PDF viewer
View PinOut
View Tip
- W -
WAIT
WAITKEY
WAITMS
WAITUS
WEND
WHILE
WHILE-WEND
Window Arrange Icons
Window Maximize All
Window Minimize All
Window Tile
Windows Cascade
WORD
WRITE
WRITEEEPROM
- X -
X10DETECT
X10SEND
XRAM
XRAM CF-Interface for simulation
XTEADECODE
XTEAENCODE
