Adding XRAM
Top  Previous  Next
Some AVR chips like the 90S8515 for example can be extended with external RAM (SRAM) memory.
On these chips Port A serves as a Multiplexed Address (A0 – A7)/Data (D0 – D7) bus.
Port C also serves as the upper Address bits (A8 - A15) output when using external SRAM.
The maximum size of XRAM can be 64 Kbytes.
Example: The STK200 has a 62256 ram chip (32K x 8 bit).
Here is some info from the BASCOM user list :
If you do go with the external ram , be careful of the clock speed.
Using a 4 MHz crystal , will require a SRAM with 70 nS access time or less. Also the data latch (74HC573) will have to be from a faster
family such as a 74FHC573 if you go beyond 4 MHz.
You can also program an extra wait state, to use slower memory.
Here you will find a pdf file showing the STK200 schematics:
http://www.avr-forum.com/Stk200_schematic.pdf
If you use a 32 KB SRAM, then connect the /CS signal to A15 which give to the range of &H0000 to &H7FFF, if you use a 64 KB SRAM, then
tie /CS to GND, so the RAM is selected all the time.
xram
