Will generate label info in the report.
$MAP
The $MAP directive will put an entry for each line number with the address into the report file. This info can be used for debugging purposes with other tools.
$MAP
The report file will not contain the following section :
Code map
Line Address(hex)
1 0
9 36
26 39
30 3B
31 3E
32 48
33 4B
36 50
37 56
42 5B
43 6C
44 7D
45 80
46 81
