Includes a binary file in the program at the current position.
$INC label , size | nosize , "file"
Label |
The name of the label you can use to refer to the data. |
Nosize |
Specify either nosize or size. When you use size, the size of the data will be included. This way you know how many bytes you can retrieve. |
File |
Name of the file which must be included. |
Use RESTORE to get a pointer to the data. And use READ, to read in the data.
The $INC statement is an alternative for the DATA statement.
While DATA works ok for little data, it is harder to use on large sets of data.
See Also
$regfile = "m48def.dat"
$crystal = 4000000
$baud = 19200
Dim Size As Word , W As Word , B As Byte
Restore L1 ' set pointer to label
Read Size ' get size of the data
Print Size ; " bytes stored at label L1"
For W = 1 To Size
Read B : Print Chr(b);
'include some data here
$inc L1 , Size , "c:\test.bas"
'when you get an error, insert a file you have on your system
