$FRAMESIZE
Top  Previous  Next
Sets the available space for the frame.
$FRAMESIZE = var
A numeric decimal value.
While you can configure the Frame Size in Options, Compiler, Chip, it is good practice to put the value into your code. This way you do no need the cfg(configuration) file.
The $FRAMESIZE directive overrides the value from the IDE Options.
It is important that the $FRAMESIZE directive occurs in your main project file. It may not be included in an $include file as only the main file is parsed for $FRAMESIZE
$SWSTACK, $HWSTACK
'name                     : adc.bas
'copyright                : (c) 1995-2005, MCS Electronics
'purpose                  : demonstration of GETADC() function for 8535 or M163 micro
'micro                    : Mega163
'use in simulator         : possible
' Getadc() will also work for other AVR chips that have an ADC converter
$regfile = "m163def.dat"                                   ' we use the M163
$crystal = 4000000
$swstack = 10                                               'default use 10 for the SW stack
$framesize = 40                                             'default use 40 for the frame space
